Old 02-27-2014, 02:57 AM   #1
Yeah, 1v drop is pretty big. This is a common problem among all older cars, wire oxidizes and resistance increases, as resistance increase things heat up which further increases heat and can also cause wires to oxidize faster... vicious cycle. The old wire type fusible link used from '86.5 up to the mid '89 model is famous for causing voltage issues. It can be swapped with the sealed FL used later on.
