Old 10-21-2005, 01:23 PM   #2
SupraMan1784
SP58GT
mmm...i dont think this problem has anything to do with him having the upper end rebuilt...teh tranny is connected to the bottom end via crankshaft, this is interesting...the mechanic is right though...4th gear shouldnt stop working for no apparent reason, i think its the transmission gears, not the clutch...if it was the clutch you would tell from teh slippage or it just wont engage at all, check if the clutch fluid is full, and the oil levels are ok, but i think your gears just arent engaging for some reason...hmmm....i cant tell you exactly what it is at the moment but ill try and find an answer
Now: Saving for an MKIV
Broken Rides:
