Old 12-08-2013, 08:12 AM   #1
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Hi, pwpanas is right that information you gave us does not help at all.
What gearbox are you running, what fuel you going to use there alot more then just slapping a big turbo on and making 800hp.
Cam gears will not help you gain power without any cams.
Everything you need to know is in the FAQ, feel free to ask anything after reading through it..
Lightened flywheel: Wont make more power.
Stronger plenum: what do you mean stronger.?
Air intake: Is that now a better filter.. If so won't gain much
Better extractors:?
Cam gears:wont do much without cams
Quick spool manifold:?
Motec antilag:?
warmkop is offline   Reply With Quote
