Old 10-01-2013, 02:08 AM   #1
The A143E should be fine. There was a beefier version but I think that may have more to do with the year than the engine trim. The 7M-GTE also has an oil cooler and recommend you don't try to go without it. A fair amount of the things you're going to need to look out for will depend on the year of your car and the year of the engine and ecu/wire harness. The pre89 models used the same mounts and the 89+'s different mounts.
