Old 09-24-2013, 09:08 PM   #33
ccguy
ccguy is on a distinguished road
well i pulled the motor harness and checked every wire. i found the shielded o2 wire was grounding to the inner wire. so i fixed that. everything else checked out good. so shit.
i unplugged the knock sensors at the ecu and it threw the code. and made no difference. i already did the rewire and that fixed the original wiring cel code.
as of today i started it and it was hard to get to fire. even ran crappier than normal. it still backfire POPs into the intake manifold when it is doing the hesitation.
also i unplugged the oil pressure wire to the ecu and it made no difference in how it ran. also my oil pressure is reading high or it at idle (so i might have a new oil pump in my future if i dont light this thing on fire only to piss on it to put it out
on this thread http://www.celicasupra.com/forums/sh...issues-bucking!
it kind of sounds like my shit and he replaced the afm with a maft and gm meter.......
i think i am going to try a new afm and see if that works???? i have tried 2 other used ones and to no avail.
could i go the maft rout or should i maybe go for the maft-pro???? i think my main problem is the tccs system being retarded somewhere in the mix.
the maft pro would basically replace my tccs ecu correct???
thanks for all the input.
1980 toyota 4x4 truck
1987 7mgte motor, 3" exhaust, water to air intercooler.
4.88s locked, dual cases, lift.....
ccguy is offline   Reply With Quote
