Old 09-12-2013, 11:27 PM   #1
mattmk3
mattmk3 is on a distinguished road
What specifically is your issue with the idle? Do you have a wideband installed? Is the ECU running in a forced, full time open loop mode (I don't recommend it with the Toyota TCCS systems)? Leave the bypass screw on the AFM alone, you don't need to use it in conjunction with the NEO.
Unless the ECU is put into a constant open loop mode (can be accomplished via a few different methods) the ECU will work to adjust the idle AFR on its own just as it does during low to medium load engine operation. This is closed loop mode. The only time you can manually affect the AFR without the ECU fighting you is when it's operating in open loop mode. Open loop mode is engaged when the engine is first warming up, throttle is at 70% or higher (I think it's about 70%), or there is a fault with certain components such as the O2 sensor... These are your tuning windows. Any tuning of the idle AFR will need to be done when the engine is in open loop mode. Tuning should be done to keep the cold idle AFR at about 13:1. Don't try to stray from the ECU's normal operation when it comes to tuning idle, cold operation and closed loop operation... just tune it so the ECU doesn't have to work it's ass off and so the two systems will play nice with each other.
Well that makes a lot of sense! Thanks for clearing that up. How long do you suppose it takes the ECU to learn a new idle when i put the Lex afm in? And the proper reset for the ecu is pulling the ecu fuse from the fuse box under the hood for a minute or so correct?
As for the adjustment screw on the lex afm, what's a good position to put it in? (because it's not where it is stock, I already screwed around with it a while ago and i'm back at it so i don't remember where it was originally)
Thanks!
87 turbo 5spd targa - 340whp @ 12psi
60-1 ct26 -- Head port and polish -- 550cc injectors -- 3" DDP + 3" straight pipe -- Areomotive AFPR -- CXRacing fmic -- Apexi' NEO --
mattmk3 is offline   Reply With Quote
