Thread: insane 7mge
Old 07-11-2013, 03:48 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Injectors may be different, there was a change at some point between low and high impedance, although i cant remember the details. Exhaust cherry red sounds to me like you have retarded ignition timing. Just to be clear, you verified your cam timing is spot on, then brought the engine to operating temp, and then set your ignition timing to 10 BTDC with the jumper wire in place?
Also, why did you swap any electronics? Did the 89 not come with an intact engine control system?
