Old 05-25-2013, 05:29 AM   #1
spainobain1234
spainobain1234's Avatar
spainobain1234 is on a distinguished road
Default BapBapBap Fuel Cut?
Originally Posted by suprra_girl View Post
if it does a bap bap bap noise it is NOT fuel cut so don't waste your money buying one
so you're saying that when you run 6 psi it doesn't cut at all
but when you run (what psi???) it does cut
what psi are you trying to run?
Hey Girrrrllll. First off, I LOVE YOUR CAR, secondly,
I am hitting the bap bap bap kind of fuel cut like you explained! PLEASE HELP!
I am at 9psi, Gt35 turbonetics turbo, lexus AFM and 550cc RC engineering injectors, Walbro fuel pump, and Adjustable Fuel Pressure Regulator...
Stock ECU, and I only want 350 Hp. My wastegate wont allow lower boost than 9 psi and I am hitting the bap bap bap fuel cut. I have a EUGO guage to moniter my air flow fuel flow ratios, and it is rich all the time even when hitting fuel cut "bap bap bap" and it bucks the car when this happens, is a HKS Fuel cut defencer safe if i carefully watch the air flow ratios?
spainobain1234 is offline   Reply With Quote
