Old 05-12-2013, 12:51 AM   #1
sounds like your air flow meter.
pop off your air filter and push in the flapper inside your AFM with key in ON position. you should here the pump turn on. otherwise test it with a multi meter and ensure its plugged in.
also test your fuel pump relay, and check for codes.
