Old 05-09-2013, 12:59 AM   #1
Check for diagnostic codes and post back (see the FAQ for instructions if needed). I'd guess the timing is off (mechanical or ignition), bad AFM or a bad knock sensor/knock sensor wiring.
EDIT: So the CPS innards are all exposed? Add, screwed up CPS to the list then (responsible for ignition timing).
