Old 05-03-2013, 01:12 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
I'd *personally*go with 75 if you're running studs/nuts to be honest, as the amount of torque that's required to produce the same downward pressure is less than the equivalent with bolts due to the reduced friction between nut/stud/washer compared to bolt thread/block thread and bolt head/washer... My reasoning being that 75-78lb/ft works fine for composite H/G and stock bolts so it should work fine with studs/nuts too. For ARP bolts on the other hand, I'd stick to their recommended torque.
Saying that, I don't think it'd do any harm to use ARP's recommended torques on studs/nuts either since, being the stud/nut or bolt manufacturers, they know what they're talking about & you won't be stripping any threads.
At the end of the day it's up to you but I don't think there'll be a problem using either setting as long as the lube you use is ARP too
