Old 04-21-2013, 09:12 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
-You would need to get a turbo kit for your car, something like this.
http://www.suprastore.com/quprost2jnon.html
-A thicker head gasket like 1.3mm.Need to drop the compression.
-Fuel system upgrades. Pump, injectors, Fuel pressure regulator.Stock fuel system won't supply enough fuel.
-Upgraded clutch kit as the stock clutch won't handle the new power.
-Intercooler kit.
-(Upgraded ignition system)not sure how much the stock ignition can handle.
-Stand alone management system or piggy back system (chip).
Here's another option. Everything you need is here:
http://www.boostlogic.com/catalog/p1...duct_info.html
Life begins at 30psi.
