Old 04-04-2013, 09:05 PM   #1
michel
michel is on a distinguished road
did you verifie your rear weel bearing inner and outer, on both side,. i had the same problem on my 85 supra ,ended up changing the rear diff. for a tru-trac,with all new bearing and ended up with the same problem(noise)in the rear. but i got a great diff.good for min. 300 hp.with no lose play .ended up changing the rear bearings and voila, good as new,by this time its all new.$400.00 total...
michel is offline   Reply With Quote
