Old 03-23-2013, 04:55 AM   #1
mechrider89
compression test will tell you there, stock compression should be between 175-180 psi. Could also be your cold start injector or your cold start injector switch which is I believe the brown sensor on the thermostat housing, I've been having a similar problem and was told that would be the main culprit.
