Thread: ct-26 questions
Old 03-14-2013, 07:46 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
If it was me I'd get an aftermarket CT26 like the one I in fact did buy for ?215 ($350 ish?) just to get you running (and don't forget the stock CT26 can about double the boost to 12psi approx. anyhow)
Then you could spend the money you would have spent on the modded CT26 on stuff like upgraded injectors/fuel pump/FPR/MAP sensor etc and get all that stuff running reliably together before taking the jump to a bigger turbo, which by then should just slot in with the rest of the kit able to handle over 12psi
