Old 03-14-2013, 06:04 AM   #1
I'd start with suspension and brake upgrades, then start collecting parts. Some things such as a fuel controller, wideband controller, adjustable FPR and stronger fuel pump may all be installed while still running the N/A and it will give you a chance to learn the fuel controller. You can also install a good oil cooling system on the GE which will still be used on the GTE.
