Thread: Accordion Hose
Old 03-13-2013, 08:09 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
If you have a turbo? The recirculating BOV could have been replaced with an atmospheric BOV (PSHHHH! noise letting off the gas?).
Few more details of the car would help & a pic of the hole you're talking about, if it IS the BOV replacement this can cause rough running in 3 ways.
First way is if the wrong type is fitted (cheap single piston BOV will cause a vacuum leak at idle, you need either recirc. or twin piston) or if the original has just had one end disconnected.
Second is if you have a twin piston that's not sealing for some reason (some are adjustable, or secondary piston could just be stuck or leaking)
Third reason (less likely) is with atmospheric BOV's, when you let off the throttle from high boost situations the engine can run rich momentarily due to the (already metered by the AFM) boost air being vented instead of making it into the motor.
HTH
P.S. Pandrade, the other hole under the accordion hose is power steering full lock idle-up valve IIRC
