Old 02-06-2013, 07:23 PM   #2
Check for stored diagnostic codes as well: http://www.cygnusx1.net/Supra/Librar...ection=AT&P=13
When you get the fluid changed make sure the transmission fluid cooler is getting flushed too. I can recall if there's a thermostat on it or not, if there is the cooler won't get cleaned out unless the fluid is hot or the thermostat is stuck open (another possible issue).
