Old 02-05-2013, 08:43 PM   #2
pandrade
pandrade is on a distinguished road
im gonna get the simple stuff out of the way. 1st off have you checked the gear oil? maby try to do a flush and top off whith new oil( mine seems to like moble 1 synthetic more than others and its sold at advanced auto parts). try checking the clutch cylinder to see for damage as well as the slave( maby performe a clutch fluid flush and make shure the peddle is adjusted correctly), i doubt thats it but the more problems you can rule out the better
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
