Old 01-20-2013, 08:28 PM   #22
Codyjamesuno
I don't think they'll fit properly but I'm not sure. The proper offset for oem-width wheels (8.0" front and 9.5" rear) is +50mm.
Offset is all about the position of the hub mating surface relative to the center line of the wheel...so no, a positive offset does not necessarily mean they'll stick out.
well they fit on the car fine, but they do stick out a little bit in the rear and a tad bit on the front. I don't know if thats bad or not, they rub a little bit on the arches but won't the coil overs allow me to correct that? Those are installed tomorrow. Here is a picture of the old & new,
ID:	4753   Click image for larger version
ID:	4754   Click image for larger version
