Old 01-18-2013, 07:36 PM   #30
interested!
Question http://www.toyota-supra.info/forums/mkiv-supra/20746-intermittent-miss-up-to-2k-and-i
Hi! , No problem ! Question ? : is the engine a high miler from new without top-end overhaul ? -- The valve seats and valves may have some pitting and this is letting the pressure through , my 7MGTE head needed an overhaul ,the seats and valves desperately needed recutting/refacing following a BHG as they were severely pitted ,a leaking ( oil ) turbo and general clean-up . I've had two engines where the inlet valves have split at the seat and burnt away , one was nearly new , the other a high miler . both were misfiring .
