Old 12-06-2012, 01:40 AM   #33
ccguy
ccguy is on a distinguished road
-ok so i just checked the tps at the ecu with it running.
-vta at idle is .48 volts
-the stumble starts at .74 volts. (also at 2500 rpm)
-once the stumble starts if i press down on the petal it increases in volts to the ecu up to ~3.7v.
-so i am back to thinking it is a boost/egr/vac leak or something like that.
when the throttle is depressed past the .74 v quickly to say 1.2v it revs up like no problem or stumble.
then when the rpms are still up if i rev it again it will rev like a normal engine. i can hear the bov once i let off of the petal and the throttle body is closed.
i plugged in my spare cps and pulled the fuel pump fuse. turned the ign on and put a spark plug in the end of the #1 plug wire and grounded it to the body. as i turned the spare cps gear the plug would spark the same time the injector would click/fire. so i know my wiring and ecu are seeing the cps signal and telling the injectors to fire and the coil as well.....
1980 toyota 4x4 truck
1987 7mgte motor, 3" exhaust, water to air intercooler.
4.88s locked, dual cases, lift.....
ccguy is offline   Reply With Quote
