Thread: 87 turbo
Old 11-30-2012, 06:32 AM   #2
See the thread about checking error/diagnostic codes in the MKIII FAQ section.
Yes, when the ignition is turned to the "ON" position but the engine is not running the check engine light is supposed to be on. Once the engine is turned on the light will turn off unless certain critical error conditions (very high level warnings) have been recorded. There are many problems which may cause the light to turn on only once and many others which won't trigger the check engine light at all so you should check for diagnostic codes anytime you have problems and it's a good idea to check them whenever you change the oil or even when you just check the oil while getting gas.
