Yes with will fitment proper offset is everything. My friend is running a 17x9.5 in the rear with a 2754017 tire which doesn't rub with his h and r springs. If you are rubbing with a 225 you need a different wheel. Changing things like offset and overall wheel diameter can have negative effect on handling and suspension geometry.
