Old 11-09-2012, 10:01 PM   #2
A lot of people find their lighting to be worse when using LEDs... bad hot spots and fast fall off. An aging dimmer circuit can often cause dim dash lights as well as aging bulbs.... old bulbs do not burn as bright as they did when new(er). To bypass the dimmer, unplug it and insert a wire jumper across the two striped white wires running into the dimmer's harness. White with black stripe to white with green stripe.
