Old 10-24-2012, 06:44 PM   #1
Ranma
Ranma's Avatar
Originally Posted by interested! View Post
Hi! -- I've been away from my car for a while but now I have carried out a deep investigation and found that the problem was --a lamp failure unit
partially full of water , this was shorting out the lamp curcuit when braking , deeper investigation found that the lip under the rubber weather trim had rusted away in several places allowing water to enter the interior ,AND ,after opening the unit I found the curcuit board had corroded away --see picture above . I will now repair the lip and search for another unit , this one has been eaten away too! . The next unit I get , I will drill some drainage holes in the cover and then reassemble , purely as a secondary precaution.
Well remove and replace the faulty parts. Should be easy enough, go to Radio Shack for the parts. The board is fine, just repair it.
