Old 10-23-2012, 12:23 AM   #1
887mge
887mge is on a distinguished road
For Pre-89:
1. Find the fog light relay, cut the white/green wire (pin 3) and ground it.
2. Find the fog light switch, cut the red/black wire (pin 4) and connect it to a switched +12VDC power source. See Note
For 89+:
1. Find the fog light relay, cut the red/black wire (Pin 1) and connect it to a switched +12VDC power source. See Note
2. Find the fog light switch, cut the red/green wire (Pin 4) and ground it.
Note: For example: splice it into the black/red wire (Pin 2) on the cruise control switch (pre-89) or cruise control main relay (89+), or splice it into the red/yellow wire (Pin 2) on the fog light relay, however this will result in the fog lights functioning even if the car is off.
the car was made in july of 1988 i am guessing that pre89, so i followed ur steps. and nothing i am still not getting any power at the fog lights there is power goin to the switch and the relay any ideas ????
887mge is offline   Reply With Quote
