Thread: Uh oh brake!!!
Old 10-22-2012, 09:07 PM   #1
97SupraTT
97SupraTT is on a distinguished road
Do your calipers need to be replaced? Or you just want to? A brake job normally consists of pads, rotors and bleeding the brakes. I’m not very current with mkIII's so some others can chime in one which parts to get. It is a job that one could do themselves. Bleeding the brakes will require an assistant. If you are questioning it, I would probably just have someone do it or at least have someone that has worked on brakes helping you. You don’t want something to go wrong after the work is done.
97SupraTT is offline   Reply With Quote
