Old 10-07-2012, 08:00 PM   #1
Wileyk24
Wileyk24 is on a distinguished road
Ok so no change in the radiator fluid level. The overflow bottle dipped slightly, less than an inch. The car is not overflowing coolant onto the ground either.
So today I decided to test the thermostat. I took it out, checked the bottom an it is a 195 degree tstat. I proceeded to boil it and with a thermometer found it wasn't opening until well after 200 degrees. Brand new unit, not functioning properly. So I went to autozone to get a new one and the system said I needed a 180 degree stat. So I bought it and took it home and boiled it. The new one open as it should and seemed to open easier than the last. Time to install.
I installed the new tstat, topped off all fluids and took her for a test drive. Good news, I made it a lot further than just one block. I actually drove all around town and on the highway. The car felt good, but my temperature gauge is settling at 3/4 the way up the temp gauge and staying there. Regardless of how I am driving.
So when the car is idling the temp gauge stays right in the middle. Once I start driving city or highway it goes up to 3/4 and stays there. Once it is up there it won't come down until I shut off the car, even at stop signs it stays up there. But once the car is off, I turn the key back on so the gauges are powered and the temp gauge sits at slightly under halfway which is perfect...
Anybody experience this before?
Wileyk24 is offline   Reply With Quote
