Old 09-28-2012, 10:45 PM   #12
I've never found Vf to be all that useful for tuning. It's a decent diagnostic aid but unless you're trying to maintain a stock tune it's not really helpful. Setting it up is easy enough, you wire the Vf pin to one of the MAFT Pro aux inputs, set the Aux In parapeter in the MAFT Pro's CFG Settings menu to 0 and then in the SensorMonitor you set one of the four monitors to Ax1 to see the readout (0v to 5v). You'll need to define the input in TunerPro if you want it to show up in TunerPro's logs.
