Thread: Engine problem
Old 09-25-2012, 01:52 AM   #2
Originally Posted by Life is Supra View Post
I know it isnt a boost leak but I didnt think...yes there was code 51 and I will check it tomorow and will post.And u think the problem may lay in air flow meter?
I said the AFM is a possibility but it's not the only possibility. I would start with fixing the TPS error (code 51) as that's another thing which could cause the symptoms you have. And ignition problem is another possibility too but TPS is where you need to start since the ECU is already telling you something is wrong with it.
