Old 09-21-2012, 11:38 AM   #18
Travis89Turbo
Travis89Turbo's Avatar
I used the same o2 sensor for both tests just switched locations with my wideband afr.
I did a pressure check on the intercooler and piping but with the turbo pulled off I couldn't do it through the intake of the turbo yet.
Could still possibly be a clogged injector but the compression test will let me kno that tonight.
If it is rings I won't be rebuilding the GE. The limits are so tight on these motors I don't trust it with just a plasti gauge and don't have any better or special tools for that. So I will be looking into a 2jzgte swap with my single on it and pull the jdm twins. But would much rather not have to do that. Hopefully its not a compression issue in the bottom end. I will keep you posted!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
