Old 09-19-2012, 01:48 AM   #1
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
I made a cheap tool to tighten down the 14mm allen center galley plugs. I used a 14mm bolt head
in the allen hole and 2 jam nuts tighted together on the threads. you just need to get a socket over the top jam nut to tighten. use decent quality material or else it could break / strip the threads. To sop up the oil with the spark plugs in I used a bent nose pair of tweasers to hold a patch of paper towel.
