Old 09-02-2012, 04:34 PM   #34
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default Need help making power 94tt
1) Be sure to run a brand new fused circuit from the battery, triggered via 30+ amp relay
2) Be sure to use at least 14 gauge wire. Anything less could heat up and the last thing you want in your fuel tank is a hot wire.
3) Use the oem ground pin to get power for the 2nd pump through the top of the fuel tank. Run a 14 gauge wire to a 1/4" threaded rod run through the tank cover to ground both the oem pump and the new pump. Do this instead of trying to run a wire through the top of the fuel tank, as fuel and vapors will flow through the insulation of the wire.
4) Run at least a -6AN line for the new pump, and run that entire system (with inline filter) to one side of your aftermarket fuel rail
5) Use a fuel pulsation dampener bypass from the oem fuel line to the other side of the aftermarket fuel rail
Any other questions be sure to ask...
1)new circuit is in with relay
2)used 14guage wire
3)Ran wires through the top of tank sealed them with srink strips.
4)used an6 line with filter.
5)Do i need the the FPD wont the aeromotive FPR sort that out.
warmkop is offline   Reply With Quote
