Thread: Engine Stalls
Old 08-22-2012, 11:50 AM   #1
lmmr74
lmmr74 is on a distinguished road
What troubleshooting have you done so far? Are the spark plugs good? Spark plug cables? Any diagnostic codes stored in the ECU? Is there oil in the spark plug galley? Have you inspected the ISCV (Idle Speed Control Valve)? Is the car stock or have you made modifications?
No codes stored on the ECU. I will replace the spark plugs. The only modifications i did, was removing the stock air filter by a cone filter, directly attached to the MAF.
One other thing i forgot to mention was that when i shut down the engine there was a strang noise coming from the charcoal cannister.
Is it normal to be hard to start an hot engine?
Thanks!
lmmr74 is offline   Reply With Quote
