Old 08-18-2012, 06:25 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
In stock configuration, these are non-interference engines; you can have a valve fully open and the piston at the top of its stroke, and there will be no contact. Even in an interference engine, the timing would have to be off a considerable amount in order for pistons and valves to make contact. I can't say for sure, but I'm fairly confident that .4 mm will not be enough of a difference to cause contact between the pistons and valves (especially if it is timed properly).
