Thread: E85 help!
Old 08-02-2012, 01:32 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by fastsupra View Post
I have been reading into E85 and have been very interested in possibly switching over to it but I have a couple of concerns. I am currently running the AEM EMS V2 and was wondering how I would go about making sure that when I fill up at the gas station that I am getting enough of a ethanol content to make sure it runs correctly because Ive read that the contents can vary...
The better E85 systems use a sensor which dynamically determines the exact gasoline:methanol ratio, and auto-tunes appropriately
...Also, when I go to fill up at the station and I'm going from 93 to E85, how would I know Im getting enough ethanol to run my E85 map?...
Again, the map needs to be dynamic, not static.
In order for me to switch back and forth, I'm going to have my shop install me a knob that I can turn to go from my 93 map to my 93+meth and then E85.
My main concerns are mainly how to make sure Im running the correct octane for my E85 map and how I would go about switching between maps when I fill up. Should I hang my head in shame for not going the ProEfi route? Or will I be able to make E85 work with the AEM?
Thanks for the help!
I believe that the gasoline:ethanol sensor can work with the AEM v2.
Life begins at 30psi.
