Old 07-27-2012, 02:08 AM   #1
Wileyk24
Wileyk24 is on a distinguished road
Default Parts are in!!!
Ok guys, parts are in. I plan on stating the teardown this Saturday after I get off from work around 4:00pm. Before/During/and After pictures coming soon. I will put up a pic of the new goodies too.
Here's the breakdown of what I ordered.
Toyota Head Gasket Kit: Part Number: (04112-42023)
Contains all the gaskets and seals you will need from the head gasket up.
Cost: $290.62 from toyotapartszone.com
Toyota Water Pump Assembly: (16100-49755)
Contains water pump and WP gasket
Cost: $79.06 from toyotapartszone.com
Gates Timing Belt Kit: (TCK237)
Contains timing belt and tensioner(idler pulley), 2 Camshaft Seals, and a crankshaft seal. It does not contain a new spring for the tensioner.
Cost: $59.79 from THMotorsports
Toyota Tensioner Spring: (90507-18008)
Cost: $5.61 from toyotapartszone.com
ARP Head Bolt Kit: (ARP-203-3902)
Cost: $106.58 from Summit Racing
ARP Assembly Lubricant: (ARP-100-9909)
For 7 bucks, why skimp here if you are going this far???
Cost: $7.02 from Summit Racing
So far I am all in for about $620 w/ shipping to give you guys an idea of what the total head gasket/timing belt and waterpump replacement procedure will cost you. Keep in mind I still am going to have the head checked, milled, etc. I can't imagine this whole project coming in any less than $1000. Guess we will see.
More to come soon.
Kris
Wileyk24 is offline   Reply With Quote
