Old 07-01-2012, 06:35 PM   #1
wayja
wayja is on a distinguished road
Ok, here is what I done so far. I have resoldered the wires at the connector that goes to the coil pack and replaced the ground wire to the coil plate. Still no joy. After doing the work I cranked the engine over and then checked codes. All I am ever getting is 51. That shouldn't prevent spark should it? I have the cover off the back of the ignitor and get 12v on four wires with the key on. Is that normal? When I crank it I am not getting any voltage to light a trouble light. There is no tach movement when I crank it over either. If the ignitor was bad, would it trigger an alarm code of some kind? Any ideas would be greatly appreciated.
Thank you.
wayja is offline   Reply With Quote
