Old 06-27-2012, 06:53 PM   #1
wayja
wayja is on a distinguished road
Originally Posted by interested! View Post
Hi! again , The coil plate is insulated and also the cam cover so it is very important to make sure the plate is grounded to the cylinder head to complete the curcuit , the wires to the coils are FEED/LIVE , it may be an idea to check continuity THROUGH the coils to the ground plate as well . There are several ground wires under the inlet manifold ( my engine is a 7MGTE ) and these were the cause of not sparking -I forgot to connect them , they are hidden , you will need a good mirror . The colour of my coil plate / ground wire ( green with yellow stripe ) is the UK mains wiring code for EARTH/GROUND.
Thank you. I will have a go trying to find the ground wires and double check the coil plate grounding this weekend. I will let you know the results.
wayja is offline   Reply With Quote
