Old 06-27-2012, 06:05 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
The ISCV is the Idle Speed Control Valve. It plugs into the top portion of the intake manifold towards the front of the engine, and I believe it has two coolant lines running to it, as well as a 6 wire connector.
The "sensor" on the intake with the banjo bolt sounds like the cold start injector. From your description, it sounds like this is physically present, just not plugged in.
The IDL circuit is a part of the TPS. I believe it tells the computer that the throttle is closed, and that the engine should be idling at that point.
