Old 06-27-2012, 08:26 AM   #2
wayja
wayja is on a distinguished road
Hello interested! The history of this car is, I purchased after the previous owner installed a new head gasket and couldnt get it running. It has new coil packs, CPS, and all relays have been replaced. I have been working on it as time allows. I put a new connector on the CPS, as it seems to be a source of trouble. Two times while cranking, I had spark, that lasted a brief time. I will double check the ground at the coil plate, and the grounds you recommended.
Thank you.
wayja is offline   Reply With Quote
