Old 06-26-2012, 09:43 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Setting the dizzy that way should get it close, but you will need to fine tune the timing with it running. If you havent already, fire it up and slowly rotate the distributor and see if that helps. If you can get it running long enough to reach operating temp, then jump the diag box and set the ignition timing to 10 BTDC. I'd like to rle out ignition timing before moving on to other possibilities
