Old 06-23-2012, 06:02 PM   #1
ccguy
ccguy is on a distinguished road
i dont think it is fuel pressure. the plugs are dry sooty, and the fuel is going fast.
i changed the cps and same things. no boost leaks, i tested using the smoke trick and the soapy water while pressurizing the manifold.
i am starting to really lean to the afm or the wiring to the ecu from the tps??????????????????????????????????????????????? ????????
ccguy is offline   Reply With Quote
