Old 10-17-2005, 09:16 AM   #1
nickvash0104
nickvash0104 is on a distinguished road
Sounds like the birdcage... but what is it doing next to the door warning light? If memory serves, starting from the top left and going clockwise, it goes light failure switch light, door open light, check engine light, ABS failure light in that small four-light cluster.
If it is indeed the birdcage (which is normally the light on the dash farthest to the left) then you are low on coolant in your system, usually both in the engine and in the overflow container. Usually this is a very bad sign.
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
