Old 06-18-2012, 06:46 PM   #1
pandrade
pandrade is on a distinguished road
ok. when you installed the new cylinder did you bench bleed it, and after adjusting the pedal have some one pump the clutch and you bleed the clutch from the slave. if not maby over time the little air that was trapped plus more air getting into the lines made it over flow( or could be a cloged line) the only reson i could see it leaking into the carpet again is maby you damadged the cylinder durring install, or the pedal wasent 100% dead on and maby you wore out the seals prematurley
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
