Old 06-14-2012, 04:06 AM   #1
Tricks.... Yup, a lift and about 10 extensions to reach the upper bell housing bolts. If I remember correctly, you'll need to loosen the motor mounts too and a transmission jack... Oh, and as always, drain it first. Getting it back in, with everything lined up and properly torqued is the best part.
I'm not really kidding about this. Without a lift it's utterly miserable.... with a lift it's well, only a little better.
Here's Toyota's instructions on it. Read through it thoroughly before you start.
http://www.cygnusx1.net/Supra/Librar...Section=MT&P=4
