Old 06-14-2012, 01:25 AM   #1
Code 41 is a hardware fault, not related to anything you can calibrate. If you're certain the wiring and ECU are sound then yes a new TPS would be called for. Testing information for the TPS is covered in the TSRM in the EFI section under Throttle Body.
