Old 06-12-2012, 02:29 AM   #16
akue
akue is on a distinguished road
Originally Posted by Ranma View Post
Are you sure the battery has power? If it is dead nothing you do will help. you can get a light bulb from the car and put the 2 wires on the post or you can set it up for a jump start or battery pack. The first thing in line is the battery and when troubleshooting electric start at the source.
Yea the battery has power we tried jumping the car wouldn't work I have a battery tester and it said the battery full soo I have no idea wtf is going on I cant get anything to work
Do you know where the alternater ground wire is so I can look at it? Only wire I have found of ground is the battery ground that goes to the engine itself tried seeing if that was the problem but still no power tomorrow I'm getting the 30 and 40 amp I. The engine bay fuses replaced see if that changes anything
akue is offline   Reply With Quote
