Old 06-12-2012, 02:11 AM   #16
Ranma
Ranma's Avatar
Originally Posted by akue View Post
Now thag I think of it if I have the grounds from the batter both on the frame of the car will that even work? The ground that was to the engine should be on the engine right?
Are you sure the battery has power? If it is dead nothing you do will help. you can get a light bulb from the car and put the 2 wires on the post or you can set it up for a jump start or battery pack. The first thing in line is the battery and when troubleshooting electric start at the source.
